Hello once i save a vhs tape to my hard drive is there a program that can clean it up to make it near dvd quality?
Any pointers would be apprcaited.
Results 1 to 10 of 10
Hi allsmiles42240,
The resolution of VHS is much lower than DVD, so the picture will never be as sharp.
Also, you'll have to define what you want to clean up - what's the problem that you want to solve? Be more precise, provide a screen shot etc.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
The best way to "clean" VHS is to do it befor it gets converted to digital format. This usally involves hardware such as a TBC, color correction devices. Even the VCR you use can make a big difference. Try the restoration forum for some ideas. -
Originally Posted by allsmiles42240There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Originally Posted by daamon
..... anyhow I know what you mean by those sparkles. What editor are you using? For removing something like usually requires a high end editor. Yopu can also try virtualdub or avisynth. Both are free and have hundreds of filters, I'm sure there's one just for your needs. Someone else will probably be able to suggest one.
...and to add to all previous answers: don't forget general rule about garbage (garbage in = garbage out).
Personally, unless its some really very valuable video, I don't bother with cleaning "original VHS' flavor" and I keep the captures in their "original" quality. The best you can do with source lower than output resolution is to preserve its quality, you can't 'enhance it' to higher resolution with any filters. Obviously VHS source will stay VHS quality, even if transferred to a HD-DVD. Any picture filtering always results in picture quality deterioration, be it loss of sharpness (details), fluidity of movement , etc etc... "quid pro quo"
The only "cleaner" I use when transferring VHS to DVD is standalone TBC (look it up, might be a good investment if you do alot VHS>DVD, otherwise don't bother). -
Now that I've looked I do remeber viewing some of my own tapes on an old VCR with junk cables that had these "sparkles", I hope we're referring to the same thing. These weren't evident on my capture VCR. -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best VCR to clean up old VHS camcorder tapes?
By dubarry in forum Capturing and VCRReplies: 1Last Post: 26th Jan 2011, 02:09 -
How to Save/Salvage an Oxidising VHS Tape?
By darkarn in forum RestorationReplies: 30Last Post: 26th Aug 2010, 18:54 -
VHS clean up
By tvlreject in forum Newbie / General discussionsReplies: 8Last Post: 10th Mar 2008, 00:10 -
best way to clean up super 8 footage,thats been transferred to vhs
By BCPOWDER in forum RestorationReplies: 0Last Post: 12th Jan 2008, 10:56
