I kinda know I can capture with scenelizer live and Ulead products and the lot but all of these products capture to dv then author as per project properties to dvd/vcd/svcd. Tried it in Videostudio 9, pinnacle unfortunately doesnt give me too many options. I want to capture to mpeg 4 avi file directly. I tried using virtualdub but I remember reading, it does not work with canopus products. I am just trying to find out some thing whcih directly captures in mpg4 avi.
thanks
DV does not work with transfers to Virtualdub, nothing to do with Canopus. Try Mainconcept encoder. It will convert to DIVX or XVID on the fly. Not great quality, though.
Hmm its actually the analog inputs I am using on the thing so thought there is a chance it will work in virtualdub. Isnt there any other option.
thanks -
You can use the MS Media Encoder to capture directly to WMV, at least I can with my 110. Should be the same with the 1394.....
Capturing with canopus advc 300
By blacksheepdownunder in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2010, 09:20 -
Best Practice with ADVC-1394
By kjfrey55 in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 02:15 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 22:55 -
Problem capturing using IEEE 1394 and camcorder
By Shabaman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 22nd Aug 2008, 08:04 -
Capturing live TV with Canopus ADVC?
By Deisel Weisel in forum Capturing and VCRReplies: 12Last Post: 11th Jan 2008, 00:57
