Maybe someone can tell me what im doin wrong but in either CCE or TMPGenc my VBR svcds come out blocky. I've captured some vidoe in VD with huffy at 640x480 using AIW128 pro. If I use CBR or single pass VBR in CCE the video looks good. Havent messed around too much with all the settings, just followed some of the guides. Hopefully someone has some advice for me.
Guest
Strange. Did you use the same average bitrate, that you used as constant bitrate?
I have just encoded an svcd and for the first time i used the VBR setting to see if it looked better. The constant and average bitrates used were the same and i was disappointed to see how blocky the product was. The blockyness however did really only stand out in the darker scenes. Especially the close to black colored items. Any ideas?
Taa -
The encoder allocates more bits to the high motion scenes and save bits at low motion scenes. That's why a low motion scene with dark background may look more blocky than encoded in CBR mode. High motion scenes might look better, isn't it?
You will notice this problem, if you used TMPGEnc. Generally TMPG is not the best choise, if you want to encode @ a average bitrate lower than 2000kbps.
Blocky MKVs
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Dec 2010, 16:06 -
FFMPEG too blocky
By IMC in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 17:00 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
Blocky or Boxy?
By jethroangel in forum EditingReplies: 2Last Post: 10th Oct 2007, 22:18 -
QT DV blocky playback
By Fifou in forum Video ConversionReplies: 5Last Post: 7th Aug 2007, 11:56
