Is there a way to make avis, mpeg or any other video files and convert them to Bin/Cue files??
TIA
Results 1 to 10 of 10
ImgTools will do that or here are some others: https://www.videohelp.com/tools?s=31#31
"convert" isn't the right phrase - "put them into" would be more adequate.Originally Posted by KFKMF
Continuing my old ISO/bucket analogy, you can't turn beer, coffee or any other beverage into a bucket, but you can pour it into one. My fav tool for making ISOs is ImgTools Classic (a front for mkisofs).
/Mats -
Not by itself, no. Again, you don't "make" video files into BIN/CUE - you just wrap them in a BIN/CUE.
You can then burn the bin/cue on to a recordable CD or DVD, but that will yield the same result as if you wrote the AVI/MPG files as data to a recordable CD/DVD using "any" burning app.
A BIN is just an "image" of a CD or DVD. It's not related to any video format at all. (In fact, it hasn't even to be a CD/DVD - you could make an image of your HDD, but 99.999% we're talking about CD/DVD images.)
The CUE is instructions for the burning app how to burn the BIN to the CD/DVD.
I strongly suggest you head over to the CONVERT section left, and read up on AVI/MPG to VCD/SVCD/DVD conversion.
/Mats -
If you want to watch them on your dvd player, you will need to author the files with a DVD Authoring program. Look under the tools sections for this. They are some excellent guides that tell you how to author.
For the case for mpeg1 files, you can create a VCD to watch on your dvd player by using burning a VCD compliant disc using Nero or whichever burning software you prefer.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
