Can anyone please help....
1. How do you animate with photos? For example, if you have a graphic of a mirror flowing across the screen and a photo of someone comes in from the other side and lands in the inside of the mirror. I would like this to go in the front of a slide presentation with menus and maybe one at the end.
2. In either Adobe or Vegas is there a way to automatically set the duration of the frames to fit the audio selections.
If you are using vegas, look as masks and motion in the help files and/or manual.
Not sure what you are trying to do when you say you want the video to match the length of the audio. If this newly created video made from your photos ? If so, the length is entirely up to you. If it is for video you have shot or aquired elsehwere then you can cut it if it is too long, or stretch it if it is too short. If youstretch it, you will change the playback speed.Read my blog here.
Originally Posted by scolew
I am mostly doing still images in the DVD with transitions. Some of the consumer apps that I have tried will automatically sync the timeline of photos with the audio...i.e., change the duration of each photo to match up with the length of the audio track. I just could not find this feature in Vegas or Premiere. Does this make more sense?
When you use masks and motion....do you use two seperate photos on the timeline to mesh them together with motion?
Thanks so much for all your help!!!!!! -
Using Premiere, I just cut the audio at the end of my video then I fade it out. Works great for me.
Syncing audio with d2v
By Norio in forum Video ConversionReplies: 8Last Post: 23rd May 2010, 01:07 -
Syncing and adding to audio?
By architectofpain in forum AudioReplies: 2Last Post: 20th Jun 2009, 02:03 -
editing/syncing audio
By angryassdrummer in forum EditingReplies: 3Last Post: 1st Sep 2008, 04:20 -
audio syncing
By projecttemp in forum AudioReplies: 3Last Post: 9th Apr 2008, 21:11 -
audio syncing issues
By anap in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2007, 04:11
