I have a clip I captured from my Motorola DCT-6412 and encoded using TMPGEnc 3.0 Xpress. The audio stream format was MPEG 1 audio Layer II. The output stream type was System (Video + Audio).I authored it using TMPGEnc Author 1.6. Both the .mpg and the DVD file play fine on my computer using PowerDVD. When I burn the DVD using Nero (I right clicked the video ts folder and selected "copy compilation") the DVD plays fine on my PC but
NOT in my pioneer 578A player in my home theatre setup. Video is fine but no audio. WTF am I doing wrong? I've been working on this for two days now and would REALLY appreciate your help!
If I converted the sound to WAV wouldn't that be a significant downgrade in sound quality
Thank you!!
BTW I didn't know which folder to post this in.
Wolf![]()
lot of pioneers dont play mpeg audio - i've seen 3 models that dont ..
no requirement that they have to in North America ..
convert the audio to ac3 or LPCM (which is better quality btw - as it is uncompressed)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
THANK YOU for the reply! I am doing a quick clip as AC-3 now.
Hope springs eternal. Looking on the bright side of things although this has been giving me homicidal thoughts its better than feeling suicidal cause at least I am relating to others...
Wolf
No Sound on BURNING
By mufpot in forum AudioReplies: 4Last Post: 10th Aug 2009, 14:39 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
No sound after burning
By janlafata in forum Newbie / General discussionsReplies: 6Last Post: 22nd Dec 2008, 17:21 -
By fazza8 in forum Authoring (DVD)Replies: 10Last Post: 30th Jun 2008, 06:58 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40
