I would like to make a simulated rear surround effect with sound forge.
Having some sound come from behind.
Sound forge can only do 2 channel AC3 encoding, and only if you have the AC3 plugin. You could use it to create a rear mono channel for encoding with a multi-channel encoder later. I use Vegas for multi-channel work becuase you can position a full set of channels. Sound Forge just isn't deisgned to do this.
Read my blog here.
stereo downmix: surround vs surround 2
By codemaster in forum AudioReplies: 7Last Post: 29th Aug 2012, 11:06 -
rear projection looks like convergence is off but it's not..
By BroomQueen in forum DVB / IPTVReplies: 0Last Post: 9th Dec 2009, 19:45 -
Low sound in rear speakers.
By madman1987 in forum AudioReplies: 5Last Post: 24th Nov 2008, 12:44 -
Need solution on my New Rear Projection TV
By tony1960 in forum DVB / IPTVReplies: 14Last Post: 15th Jul 2008, 18:36 -
Rear Projection TV Help
By Alienverse in forum Newbie / General discussionsReplies: 3Last Post: 13th Jun 2008, 23:34
