I just hooked up my Lite-on 5045 (has a manf. date of Nov. 2004). I noticed there is a little bit of a green tint to the picture. And when source is set to tuner you can hear a hum. I notice it already has an LP speed setting. Since I already have the 3 hr recording speed, and I don't think I will be copying VHS tapes with this unit right now my question is - if I upgrade the firmware now, can I upgrade it with the hacks later? Or do I have to wait for a newer firmware to come out to install the hacks? I also just purchased the Ilo 04 which I haven't set up yet. But when I do I'm going to install the hacked firmware because I will be using it to copy VHS tapes. Any thoughts on this would be much appreciated.
Thanks!
If you are not concerned with the Macrovision on the 5045, use the unhack firmware. You will be able to use the hacked firmware later if you decide you want to. Version 197 takes care of the green tint. The tuner hum is common and hardware related so it can not be fixed through firmware.
Had anyone updated their Liteon 5045 or other standalone to SATA DVD ?
By bithead9 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 29th Nov 2011, 18:31 -
lite-on LVW-5045
By pmitch in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Mar 2009, 03:44 -
Panasonic Firmware question
By vetski179 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 19:30 -
Firmware Update Question ##
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2008, 06:56 -
LiteOn Lvw-5045 (UK - English)
By cubud in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Jun 2007, 14:05
