Results 1 to 10 of 10
    Jan 2005
    Canada
    i have dvdshrink and i want to copy a dvd (its under 4 gb) i tried nero copy dvd (selected in ner startsmart) and dvd shrink but both the finished projects are missing the menu that is on the original....wat should i do or is there another program i can try...?
    thx
    dvddecrypter,
    mode->iso->read and save it on the hd
    mode->iso->write open the iso and burn
    Jan 2005
    Canada
    it would be the same if i used alcohol to burn it rite...?
  4. Originally Posted by dum_hobo
    Probably but I'd recommend dvddecrypter,its the best DVD ripper in my opinion.
    RIP dvddecrypter
    Jan 2005
    Canada
    i did as u suggested and use dvddecryter but after the ioso was ripped and i play it, the menu doesnt load and i jumps to the first epsiode/chapter... wat do i do?
    thx
  6. Originally Posted by dum_hobo
    thx
    I was just wondering,did you run any other software when you ripped an ISO file with dvddecrypter ? Like AnyDVD perhaps.
    Jan 2005
    Canada
    nope
  8. I asked because AnyDVD can be set to jump straight to the main movie,resulting in what you are describing.
    Your problem is rather baffling because using dvddecrypter SHOULD give you an exact copy of the original
    Maybe something installed on your PC has been set to jump straight to the main movie thus bypassing the menu.
    Jan 2005
    Canada
    so do u no where i should start to look?
  10. Originally Posted by dum_hobo
    Basically check the settings of the software you use to play the ISO and make sure anything relating to "Jump to main movie" is disabled.Or any DVD related software.
    You could also try using different software to rip your DVD eg Smartripper ,theres loads to choose from,but dvddecrypter works for most people.
