  1. can anyone here help me I recorded a movie of family and saved it as .avi but the .avi movie is 13.3gb how can I burn this to a dvd or maybe 3 or 4 as i need to convert it to dvd format so i can view it on home dvd player as i cant see this being shrunk down to fit a dvd as a dvd is 4.3gb
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    When you convert it to DVD compliant mpeg it will easily fit. 13.6 GB and probably in DV-AVI format is about an hour. Even the highest qwuality DVD mpeg will fit once converted.
    You need to convert and author it. Try out the guides section.
  3. To add a bit.
    The RUNNING TIME of the video determines it's final size, once encoded and authored, not it's file size.
    Cheers, Jim
    My DVDLab Guides
  4. Member daamon's Avatar
    Melbourne, Oz
    Originally Posted by reboot
    To add a bit.
    To add a little bit more, the running time AND the bitrate chosen during encoding are the only factors that determine the final file size.
    As thecoalman says, DV AVI of 13.6Gb will be about an hour. Using the max bitrate allowable (about 9,000kbps) this will produce an MPEG2 ready for authoring that'll fit onto one single-layer DVD.
    You might find the VideoHelp Bitrate Calculator useful - either for determinig bitrates, or for helping to understand how bitrate and running time affect the file size.
    Some ask "Why doesn't the resolution have an affect on the filesize?" - Well, it doesn't directly, but a lower resolution means that you can get away with less bitrate and so end up with a smaller file size for the same running time.
    Hope that helps...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  5. If you are new to dvd authoring (as it sounds) i suggest using a simple to use-user friendly program like Ulead DVD movie factory, it will take a long time as it's encoding stuff when you select burn dvd but it's easy to use.
    I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
    Rufus T. Firefly (Groucho Marx)
  6. Originally Posted by natty
    Windows Movie Maker - Import Video, Drag to timeline, Save to my computer - BEST FIT TO SIZE - and make it about 1 gb - save it to your desktop.
