I split some video and audio out of some OGM files, then re-encoded the video with Tmpgenc. Now my video is getting ahead of the audio. When I re-encoded the video I didn't change the frame rate, though.
I have tried using the original .wav file and the converted .ac3 audio file, and both are equally out of synch. The delay gets worse as the fideo progresses.
I should probably add that if I open a video file and check the run time, and then compare that to the run time of the corresponding ac3 or wave, they are the same.
For example, video file one is 23:44 audio file one is also 23:44 but during playback, the video appears to be about a full-second off at the very beginning, increasing to almost 3 or 4 seconds off by the end.
Any recommendations?
Results 1 to 1 of 1
Need some help with a synch problem
By kotyczka in forum AudioReplies: 3Last Post: 10th Jul 2011, 07:26 -
Tovid Synch Problem
By Ogilvy in forum LinuxReplies: 4Last Post: 7th May 2010, 14:52 -
Video/Audio synch problem
By tangomango in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 12:19 -
Audio Synch problem only after burning?
By MCPorche in forum AudioReplies: 1Last Post: 31st Jan 2008, 19:34 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47
