I have a video that plays at the wrong aspect ratio only in vlc. In media player classic it plays in correct aspect ratio. when I click 'view -> stream and media info' in vlc it shows resolution as 624x256, gspot says the same thing. When i play the video in vlc it plays in something around 900x200 how can I fix this?
Maybe the video contains an incorrect AR flag that other players simply ignore. I have had this problem in the past with people encoding 4:3 stuff at say 640x480, which would be fine if they didn't also set the PAR as 4:3. If you resize to 1:1 then you don't need to set the AR.
What kind of file is it? -
It is opendml and mpeg4 modifier says it doesnt handle that. Celtic, were you able to get yours working good in vlc?
I guess so, however I don't use VLC. But I was able to fix the AR.
How big is the file? If it is under 2GB's, you could remux it, then try MPEG4Modifier.
How to play 4:3 Aspect ratio in fullscreen using VLC,MPCHC?
By skorpinok in forum Video ConversionReplies: 8Last Post: 3rd Sep 2011, 21:53 -
Video plays in the wrong aspect ratio by default.
By jimminy_kriket in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2010, 15:05 -
VLC DVD aspect ratio
By vhsreject in forum Software PlayingReplies: 3Last Post: 21st Sep 2009, 10:12 -
Best Aspect Ratio playing .mkv video via VLC/Quicktime for viewing on HDTV
By iMacMan in forum MacReplies: 4Last Post: 19th Feb 2008, 01:04 -
.VOB in wrong aspect ratio, he-lp needed (my wedding video!)
By nicknomo in forum Video ConversionReplies: 10Last Post: 30th Oct 2007, 14:40
