I need s few ATI AIW users running MMC 7.5 to test the latest Reg Tool.
I've added the ability to set Segment Sizes more accuratly (and a way that makes more senes) plus I added direct access to the CPU load setting without having to go back into "custom" via MMC 7.5.
I'd like some help making sure I didn't over-look any problems and any suggestions are welcome. (I will implement anything thats a reasonable suggestion)
Plus if anyone wants to help fix/update the "how_to.txt" file that would be GREAT!
just email me and I'll send you the beta
if your not familiar with the tool - you must be completely out of MMC before you can run the tool - you also have to have at least one custom profile setup before it will work (with no custom profile it would have nothing to edit)
thanks
stinky
stinky@phat.co.nz
Results 1 to 12 of 12
let me try again?
or give me a diff email address - or email me and I'll put it up on some web space for you to d/l -
Stinky - I got it. Finally! Going to give a look soon. I'm in the middle of a capture right now.
Stinky... sent you an e-mail on this...
Apparently theres a significant drawback to this setting... -
I will like to help, but I'm not sure if I can run MMC 7.5 under WinME.
I have:
AMD Athlon 900Mhz
256mb ram
! Viva Mexico ! -
Ok -- didn't get to my emails yet (going there now)
was wondering if my "resolution manager" did all the resolutions we would want (I only put in those suggested by ATI) but what about 'unsupported resolutions'? anyone try them?
ok going to read my email....
iPhone 4 now has 1. 5million beta testers!!!
By ejai in forum Off topicReplies: 13Last Post: 18th Jul 2010, 06:03 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
VOB2MPG PRO - Beta testers
By ChrissyBoy in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 10th Jun 2009, 04:57 -
Beta testers needed for my Frame Capture App
By several in forum MacReplies: 2Last Post: 9th Mar 2009, 15:53 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
