:/ What hardware/software would be necessary to display an analog video source on a laptop's monitor?
I need to stream the video, as if the laptop monitor was a T.V.
Thanks for the help
Results 1 to 10 of 10
I think you will need an external device. If you are talking analog video, such as TV, then you most likely need a tuner. If you mean video such as composite from a VCR or similar, you still need a card unlesss your PC has a analog input. Computers are only digital. With a analog source, you need some sort of conversion. Internally, if you have a SVHS input, you could use that.
There are several options, a PCMCIA card for video input or a external unit with USB 2.0 output or a unit with Firewire output with a PCMCIA Firewire card in the computer. I am assuming a laptop with USB 2.0 and without Firewire internal. Too many options to give a good recommendation. Give us some more info, thanks.
Heres some info: I have a PC Card, USB 2.0, and 2 pin Firewaire ports. Let me know if you need to know something else.
Thanks -
Thanks Redwudz. You helped me find it. And for anyone who would like to set this up too.... http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1274230&CatId=1426
Great. Let us know how it works when you get it. I looked at a few PCMCIA tuner cards in the past, but a little too pricey for me as I didn't really need it. Seems to have a lot of features, though. I wonder how much antenna it would need for over-the-air reception? I have a AVER PCI tuner card I have used a few times and it worked well.
Yes WinDV has deinterlacing. The quality depends on the input card and your laptop LCD. Older LCDs have issues with lag, nonlinearity and viewing angle. All computer LCDs have poor black levels.Originally Posted by nakedape
A Laptop LCD will always be worse than a good CRT or a LCD optimised for video (Theater LCD). Use WinDVD to make it look as good as you can. -
I use PowerDVD mostly. It defaults to a reasonable display. Deinterlacing modes and other adjustments are selectable in the configuration menus.Originally Posted by nakedape
These viewers work with overlay windows. Most graphics cards support overlay these days, even notebooks. Overlay allows all display modes like brightness, contrast, gamma, etc to be adjusted just for that window.
http://www.intervideo.com/jsp/WinDVD_Profile.jsp
http://www.gocyberlink.com/multi/products/product_main.jsp?ProdId=1
Laptop HP: No more display
By themaster1 in forum ComputerReplies: 20Last Post: 4th Jan 2011, 20:59 -
Cannot display laptop video correctly through flat screen TV
By dubmunkey in forum DVB / IPTVReplies: 25Last Post: 13th Aug 2010, 07:04 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56 -
Cannot change laptop's display resolution
By edong in forum ComputerReplies: 1Last Post: 5th Oct 2007, 15:06 -
How to display RGBHV video on a Laptop Computer
By Valinote in forum Capturing and VCRReplies: 4Last Post: 9th May 2007, 18:56
