I am having trouble eliminating hiss from the audio when I capture video.
I am using MMC 7.5 (Set to full DVD capture) a built in C-Media audio card on an AMD 1600+ system. No matter what adjustments I make to audion levels or capture format the hiss is always there.
On my previous set up I did not have any problems with hiss.
Is anyone else having the same problem and know what is causing it?
PS I have also just noticed that if I de-multiplex the MPEG2, amend the sound streem so the hiss disappears and then re-multiplex - the hiss re-appears on the re-multiplex.
Help !!!!
<font size=-1>[ This Message was edited by: mjkc on 2001-12-16 14:21:05 ]</font>
Results 1 to 1 of 1
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 03:45 -
Hissing noise in AC3 File
By koberulz in forum AudioReplies: 4Last Post: 19th Apr 2011, 11:33 -
How do you get rid of hissing air noise from digital camera video
By johnharlin in forum AudioReplies: 1Last Post: 23rd Sep 2010, 00:24 -
Easycapture USB 2.0 Buzzing, crackling hissing audio feedback.
By Spyrofan in forum Capturing and VCRReplies: 0Last Post: 9th Sep 2010, 15:14 -
Hissing Sound in the Background
By Jenny in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2007, 02:04
