Results 1 to 11 of 11
  1. I have a video file that is 576x432 and I need to convert it to DVD format with TmpGenc, but I'm having a bit of trouble with the settings.
    Everytime I re-encode I either end up with video that is stretched or shrunk or video that is in a wrong resolution for use on a DVD. I want to go to 320x240 for this DVD. What do I need to change?
    Jun 2004
    USA
    I think 576x432 is PAL, if it is then you will need to convert to NTSC. I have not done that but I know there are guides and numerous threads on this site that should help you.
    bits
  3. No, it's not PAL. The Framerate is 23.976 (NTSC Frame Rate) and the aspect ratio is 4:3 (NTSC Full-Screen standard) so it's just a matter of converting the resolution...
    What I'm trying now is setting the Source Format at VGA (1:1) and setting the output to 320x240 (Low-Res NTSC DVD) Still got about 15 minutes to go on the encoding.
    320x240 is not a DVD spec. You made a mistake. 352x240 was correct.
    Anyway, you'll have a better quality end product if you use 704x480 or 352x480.
  5. Ok, so what settings to di Need to set in TmpGenc to get a 352x240 output with reasonable quality from 576x432?
    On the video tab I have:
    Stream Type MPEG-2 Video
    Aspect Ratio: 4:3 Display
    Frame Rate: 23.967 fps (internally 29.97fps)
    Rate Control 2-pass VBR
    Profile & Level: MP@ML
    Video Format: NTSC
    Encode Mode: 3:2 pulldown when playback
    YUV format: 4:2:0
    DC component precision: 10 bits
    Motion search precision: Motion estimate search (fast)
    On the advance tab I have:
    Video Source type: Non-Interlace (progressive)
    Field Order: Top Field First (field A)
    Source Aspect Ratio: 1:1 (VGA)
    Video Arrange Method: Full Screen (keep aspect ratio 2)
    Is there anything I need to change?
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Your settings look fine for 352 x 240 MPEG-2, although I must ask why you're using 2-Pass VBR for 352 x 240 ? The only reason I could think of is because you're trying to cram this as small as possible ...
    If you want the best quality, use 704 x 480 or 720 x 480 and use 2-Pass VBR with min 1000, max 9000 and avg calculated using a bitrate calculator.
    If in doubt, Google it.
  7. Originally Posted by jimmalenko
    You hit the nail on the head. It's anime that I am backing up, and I want to get about 480 minutes on a DVD-9.
    I used that bitrate calculator and came up with an average bitrate of 2085kbps, but would that be the same for 352x240 or do I need to use a different calculator for that?
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    No, that same calculator will work fine irregardless of resolution. After all, Size = Bitrate x Time, so your resolution does not factor into the mathematical side of the equation. It does, however, enter the quality part. 2085kbps will be absolutely heaps for 352 x 240, and that's using 224kbps AC3 audio too. I'd do a CBR 2000kbps encode if I were you because there's no quality advantage IMO using 2-Pass VBR in this case, and a CBR encode will be twice as quick.
  9. So if I'm understanding you correctly I'm not going to see any difference in size between a 352x240 and a 704x480...
    Am I reading that correctly?
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    in filesize ? No, resolution plays no part whatsoever. Bitrate and running time are the only contributing factors to filesize. so two identical files, one 352 x 240 and the other 704 x 480, should theoretically come out at the same size if you use the same bitrate on each.
    Resolution plays its part when you apply the bitrate to it (from a quality perspective) so you should choose either a suitable resolution for the bitrate you need to use (as calculated), or alternatively if you want to use a particular resolution, then you need to use a suitable bitrate, and may have to consider more than one disc.
  11. Ok. I understand now. I'm re-encoding at 704x480 at the same bitrate I was using before and I'm going to see how the quality is. If it's OK, I'll use the higher resolution.
    Thanks for the help.
