Hey all
I just finished getting ImTOO DVD Ripper 2, and let me tell you its great; now I noticed that the audio is a little out of sync, which I would like to fix. Now Im basically using this to copy my DVD's, so I can put them on my archos av320. Ok, what do I do so this audio can be in sync the next time I encode it. I want the final output video to be small as possible. Also the video seems to be a bit choppy like if it were to stop for a split nano second. I encoded The Hulk with this, and normally if I were to copy this movie using my archos plugged into the tv, it would take about 1.2gb's which is quite alot. Now can anyone give me some help.
P.s. Anyone know of a video compression program, so I can shrink the video files...
Thanks in advance..
ImToo DVD Ripper problem
By -phenom- in forum DVD RippingReplies: 2Last Post: 9th Aug 2010, 10:52 -
ImTOO DVD Ripper Platinum Works Well but Would Like Smaller Files...
By w6rlf in forum Video ConversionReplies: 2Last Post: 18th May 2009, 12:30 -
Imtoo dvd creator
By fromunda kid in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2008, 20:22 -
ImTOO DVD Ripper, can't rip my DVD's!!!
By Hashum in forum DVD RippingReplies: 20Last Post: 11th Oct 2007, 08:35 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 03:06
