i recently purchased a kworld usb2800r . Im using it to capture live tv as well as capture video from my8mm camera. The manual is very vague on the software setup and I can't seem to get it to capture to divx without it still ending up being a very large file. I would like to be able to fit around an hour or so in 700MB. But these files are huge after capture.. Is it just not so good software? Any suggestions on better software to use with my usb2800r? If anyone else is using the same software and has a solution to my issue..it would be much obliged.. thank you in advance for your help...
