I transferred a tape to DVD all is good except that when people are speaking there is a pop/hiss background noise that goes along with the voices it is never heard otherwise...is there anyway to clean that up? I have tried Goldwave, but it does not seem to be working very well. Any suggestions of filters/programs would be appreciated.
if you have a lot of money to spend check out the Waves Restoration bundle. X-Noise is a fantastic plugin
Hi wheezer210,
I had a recent audio problem that wasn't dissimilar to yours (in terms of audio).
Another forum user very kindly worked on my 39 second clip for me using Steinberg Clean. Other tools were used (Goldwave, Audacity, Adobe Audition, Sound Forge) - with varying results. And some more tools were suggested.
In the end, the work done in Steinberg Clean with a "touch up" in Sound Forge produced the best result.
I looked into getting a hold of Steinberg Clean and, if I remember rightly, the advertising blurb said it's aimed at / good for cleaning up audio pops an hiss.
Here's the full thread:
www.videohelp.com/forum/viewtopic.php?t=274330There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Is There a Free Program that Removes Hiss and Pops from WAV files?
By cplevel42 in forum AudioReplies: 10Last Post: 24th Nov 2009, 13:28 -
clicks and pops in very old VHS tape
By snafubaby in forum Capturing and VCRReplies: 0Last Post: 27th Sep 2009, 03:55 -
hiss removal on a good quality VHS tape?
By zee944 in forum AudioReplies: 78Last Post: 26th Mar 2009, 04:28 -
Hiss removal on a bad quality transfer?
By michel weisnor in forum AudioReplies: 8Last Post: 2nd Mar 2009, 12:42 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54
