Hello i have 2 cdz with a movie on them and i want to convert the mpg2 files to DVD so i can play it on my dvd playa. so my question is, is there a FREE program out there that i can use thats EZ to convert my 2 mpg2 files on cd-rz to DVD so i can play it on my dvd player?? please help.. Thanx to those who reply and help....![]()
Closed Thread
Results 1 to 10 of 10
The word is "author", provided your MPEG-2 files meet DVD specs. Check out the Tools section (to your left), and look at DVD Authoring Tools. AFAIK DVDAuthorGUI, IFOEdit and GUI for DVDAuthor are all free. Also check out the "Author" section under "How To" for guides on this process.
If in doubt, Google it.
No, they won't burn anything. They're authoring tools, not burning tools
What you need to do is firstly check if your MPEG-2 files are DVD-compliant (my guess is that they're probably SVCDs, which aren't DVD-compliant), then either convert them to DVD-compliant files and author them (conver tthe MPEGs to IFO, BUP and VOB files) or use software that will accept SVCD MPEGs (DVD-lab does AFAIK).If in doubt, Google it.
I use TMPGEnc Plus to encode and TMPGEnc DVD Author to author.
I'd suggest you check out the Tools section, and then the guides section. It's all there
Here's a couple of links:
Video Encoders
all-in-crap-one tools (convert and author in one step)
VSOdivxtodvd is probably one of the easiest and better tools to use for a beginner to convert a file and get all of the necessary dvd files in one click. Dvd2svcd is a real good free program. However as jimmalenko stated I have yet to find a substitute for the good old fashion way.
If they are SVCD compliant mpegs, I'd suggest running them thru svcd2dvdmpg, then author with TMPGEnc DVD Author.
Or just author them as they are with DVD-Lab, ignoring the warning about non compliant mpg.
/Mats
one topic is enough.
https://www.videohelp.com/forum/viewtopic.php?t=270841
Advice for best DVD MPG2 Muxer
By Krelmaneck in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2010, 05:51 -
editing mpg2 to dvd without quality loss
By dailM in forum EditingReplies: 2Last Post: 8th Aug 2009, 02:35 -
MKV -> MPG2 for HD-DVD Authoring
By Mickey79 in forum Video ConversionReplies: 18Last Post: 13th Feb 2008, 09:38 -
Problem converting HD (.mkv) to DVD (.mpg2) with TMPGEnc
By KPKMP33 in forum Video ConversionReplies: 4Last Post: 9th Nov 2007, 10:36 -
Convert video from 2-disc dvd to one mpg2
By gamingexpert13 in forum Video ConversionReplies: 12Last Post: 17th Oct 2007, 05:59
