  1. I want to create a DVD from my Xvid file. It has dual audio that can be switch and has an sub file. I want to author the dvd so that I can switch audio and turn the sub on and off.
    Apr 2004
    Miskatonic U
    You will have to demux both audio streams and the subtitles, encode everyting as compliant, then author using something like DVD Lab Pro or DVD Architect 3 that can handle multiple audio and subtitle streams.
    Read my blog here.
    or use avi2dvd.
