guys my printer is not recognise the ink some reason i'm using EPSON R 300 i bought new ink yestarday and steal same this the ink i bought.
OT 481- 2 -3 -4- 5 till OT 486.any help appreciated
many thanks
Your best bet is to go to the Epson site for your country and use the online support feature.
You will be connected to a "technician" and they will talk you through your problem and hopefully give you a solution.
I've used them a few time in the past and found them very helpful.
Best of luck -
Is it epson ink or a 3rd party brand ?
Not bothered by small problems...
Spend a night alone with a mosquito -
Ding!Originally Posted by iooiFB-DIMM are the real cause of global warming
many thanks guys i solved the problem i think wos it epson ink a 3rd party i bought the original ink 59 pound and it worked
tabit.
epson px720wd
By davechubb in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2012, 12:42 -
Epson Artisan 710
By xobituaryx in forum MediaReplies: 2Last Post: 25th Feb 2010, 21:33 -
FREE Epson R280?????????????????/
By videobread in forum ComputerReplies: 1Last Post: 28th Nov 2008, 10:16 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 09:19 -
Epson R280
By ultraman36 in forum MediaReplies: 2Last Post: 11th Nov 2007, 12:26
