Having a little trouble with Nero Recode (2.2.6.16).
On several occasions it has severely (miscalculated?) DVD-5(4.7GB).
I get no errors, alarms, warnings, or any indication of a problem. BUT
My written DVD has the entire movie on it (very pixelated when viewed) but only (approx) half the DVD capacity was written to. There is a good INCH from the outer edge of the disk that is not used.
This is so intermittent that I never know what I'm gonna get until I pull the DVD out of the writer when it's done. Crapola!
Has anyone experienced this type of issue with Nero? Could this be a problem with the analysis?
I have quit using Recode due to this problem, but would like to find out what the heck is going on.
Not a solution but a suggestion, have you tried writing to HD insted of DVD??? You can check results before burning. I always check results w/ Nero Showtime 1st then I burn
"Quit Playing With The Clock..."
Rudy - Funhouse pinball game -
Well...
I think I solved my own problem but does not shed any light on the "WHY".
I managed to find what I "think" was causing my problem. In the directory,
C:\Documents and Settings\All Users\Application Data\Ahead\Nero Recode
I found what appeared to be about a zillion analysis files or something. I really HATE these behind the scenes, hidden directories, that store crap that you cant find without a certified bloodhound.
Not sure, but I wiped NERO from my system, re-installed/updated and so far, my tests have been successful.
Like I said, I have no clue what, why or how NERO ended up this way, but so far so good. I fully expect this situation to happen again as I have no root cause. -
Remember what craiggus365 said though,encode to your hard drive first and then you can check the results instead of wasting your time making coasters.
XMedia Recode: Can You Set the Desired File Size?
By jdanniel in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 18:07 -
estimated size of a video clip
By ansmit in forum Newbie / General discussionsReplies: 3Last Post: 20th May 2010, 15:13 -
Nero Recode 3.0 Where is It?
By mn072065 in forum Authoring (DVD)Replies: 5Last Post: 31st Dec 2007, 14:49 -
Estimated Size Problem
By NHLroyrocks in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2007, 01:17 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
