I own a Toshiba 23HLV84 23" TV with DVD player. It is a slot time DVD player that allows the DVD to be pulled into the player attached to the side of the TV. I have purchased a miniDVD camcorder which records on 3" (8cm) mini DVDs. The Toshiba owner's manual says I can play 3" DVDs in the player WITH AN ADAPTER. I called Toshiba and they couldn't find it in the parts catalog, despite it being in their owner's manual. Does anyone know of some sort of adapter that converts a 3" DVD into a 5" DVD so I can play it directly on this player. It currently will only allow 5" to be pulled into the machine. I am stumped.
They sometimes sell at record stores near the 3"CD singles area.
I got mine ~1992, so I don't know how easy it is to get now, nor how much $$, but they were cheap then, just a bit of plastic donut ring with springy clip things to hold it on.
Do a google search..
Scott -
buy a cheap tray loading dvd player.you can pick them up for next to nothing
as for an adaptor,with a laser right next to the discs,i wouldnt chance one.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 20:01 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 14:01 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08
