    Sep 2003
    Indianapolis
    G4 (PCI) upgraded to 500 mghz and 768 memory
    10.3.9
    Toast 6.0.9 and also tried 6.1
    Reinstalled QT 6.5.2 (had 7.0.1)
    Using a Lacie (pioneer 106) ext DVD-RW
    When I try to record a Video_TS file, using DATA-ROM (UDF), toast starts up and then freezes after a second or two. It also freezes on abort. Did this on QT 7.0.1 so I reinstalled - no change
    tried sony and verbatim discs; anyone need a dozen coasters?
    all was well on 10.3.7 and 6.0.7
    Now here's the buggy part - I checked these trashed discs on disc info after a restart and toast says they were Data: Iso 9660 and not Data-ROM (UDF)
    please Help
    jjn in Indianapolis
    May 2005
    Region 2
    With version 6.0.7 or later you can use the Video > Advanced > DVD-VIDEO from VIDEO_TS option. This will also remove the .DS, .LAY, .layout files etc. automatically,
    HTH but I'm not sure it will...
    commands[128]
    Sonic please update Creator or sell it to someone so they can...
    Sep 2003
    Indianapolis
    Thank you, I tried that and it does the same freeze.
    jjn
  4. I would say it's a problem with your PCI upgrade card. If this is a B&W G3 upgraded to a G4, the G3 non-standard firewire ports and will not work. You need to get an PCI Firewire card.
    Sep 2003
    Indianapolis
    It's a G4 (PCI) which was upgraded to 500 megahz. This worked perfectly at one time. I am baffled. I've also tried to repair the hard drive with Disk First aid and Tech tool pro.
    thank you for your continued help, it is truly appreciated.
