I'd like to burn my VCD files onto 4.7Gig DVD. However I read DVD players do not play VCD files from DVD, like they can with CD's due to the 48,000 audio sampling. Is there a program that will convert these to the proper audio sampling? I have a ton of VCD files. Also, does it have to re-encode the VCD?
Hi,
Many dvd authoring programs will convert the audio for you. Just load your vcd level mpg file into the authoring program and design as normal. (of course make sure you have it set to dvd output).
DVDLab will author them, and it will also transcode audio for you.
I have a guide on this.Cheers, Jim
My DVDLab Guides -
TMPGEnc DVD Author will also accept VCD files for authoring to DVD. Not quite sure about this, but it seems that it does NOT convert the audio. It accepts 44.1Khz audio for vcd's only, and doesn't seem to spend any time converting it. Not sure exactly how this works, but it does! Not sure if they're entirely compliant.
Problems when playing DVD VOB files
By rbrown871 in forum Software PlayingReplies: 2Last Post: 25th Nov 2008, 20:10 -
playing on US DVD player multiple files....
By theRealness0820 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 13:09 -
playing files on a dvd player
By rigger1972 in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2008, 13:23 -
Playing MP4 Files on a DVD Player
By neumannu47 in forum Newbie / General discussionsReplies: 6Last Post: 10th Feb 2008, 14:27 -
dvd files not playing smoothly
By smoothie25 in forum Newbie / General discussionsReplies: 8Last Post: 19th Oct 2007, 11:58
