My friend has a Pinnacle "Movie Box" DV/Firewire capturing device. It has Component and S-Video ins/outs and Firewire thru ports. It's showing some bizarre behavior. From what I could read in the user manual, if you're using Windows XP there's no need for drivers, just like a DV camcorder. He was using that 2-year old Dell, basic model, with a Firewire PCI card and this device hooked up to it. It captures from a camera with no problems, but he can't capture using this device. Here's what it does: Plug in the device, Windows has all those pop-ups about what you'd like to do, "Use Windows Movie Maker, Use Adobe Premiere Pro, Use Pinnacle Studio, Do Nothing" etc. If you choose any of those, the applications freeze. I had him choose nothing, open Premiere Pro, and choose capture, but it freezes Premiere at that point.
Here I would assume the device is a dud. BUT, it works in two laptops that we tried with MOBO 4-pin firewire!
Now I'm assuming it's hardware failure; the Firewire PCI card. He got a new computer (off eBay, some old gamer's rig) and put the PCI card in it and had the same issue, which is why I thought it was the card. But he went to Best Buy and bought one of those overpriced $40 Firewire cards and had the same thing happen.
So, it seems as if this device doesn't like Firewire PCI cards. We haven't been able to bring in a desktop with FW on the Mobo to see if it's a difference between 4 and 6-pin, but that's unlikely. What type of device would fail like that? On two different computers with two different FW PCI cards?
Does anyone know what we could try? If this is the wrong place, could someone reccommend another forum?
By the way, here's a link to the device: Pinnacle Studio MovieBOX DV Version 9
Originally Posted by leaded
Apparently you are not alone.... https://www.videohelp.com/capturecards.php?CaptureCardRead=282&orderby=Name
Considering the amount of trouble listed there I couldn't find any reference to it on the pinnacle site. Doesn't suprise me though. Checjk to see if you are running different versions of XP, there was some issues with cams not communicating after the SP2 update.
Help with Virtualdub and Pinnacle MovieBox 710-USB
By cgarai in forum Capturing and VCRReplies: 3Last Post: 7th Apr 2012, 00:14 -
Pinnacle Studio MovieBox Ultimate vs. DVD-recorder
By fabitos in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2009, 07:04 -
Color Problems with Pinnacle Moviebox Ultimate
By fabitos in forum Newbie / General discussionsReplies: 5Last Post: 8th Aug 2009, 22:37 -
Limited capture success with Pinnacle MovieBox Plus 510-USB device
By ccooper in forum Capturing and VCRReplies: 4Last Post: 17th Jul 2009, 11:52 -
Pinnacle Moviebox
By gkoenig in forum Capturing and VCRReplies: 0Last Post: 3rd Jul 2007, 12:36
