When I created a DVD in WinAVI convertor I got a VOB file that bigger than 0.99. the size of the VOB file is 1.34GB.
I know that every 0.99GB become another VOB file.
Why the size of the VOB is bigger than 0.99GB?
Results 1 to 15 of 15
reauthor with some other tool like tmpgenc dvd author, select add dvd video and choose the video_ts folder.
http://members.dodo.net.au/~jimmalenko/test.htm might help.
If in doubt, Google it. -
Thanks but I don't want to join or burn the video.
I just want to know how it is possible that a VOB file can be bigger than 0.99GB? -
What jimmalenko said. Also, if you attempt to burn a .vob to disk, you may encounter a burning error or it just may not even burn entirely. The standard for maximum compliance .vob size is 0.99GB.
You could also load the files into DVD Shrink and burn from there. It will recreate the VOB files.
Google is your Friend -
No reason a VOB file can't be bigger. I've got 3 on my system here that are 4Gb or bigger. I just used DVDDecrypter to create one big file from some DVDs I recorded on my DVD Recorder so that I could easily edit out the parts I didn't want before reauthoring. The .99Gb size is only needed when authoring a DVD to be in specifications.
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 18:25 -
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 15:13 -
ISO file bigger than original video_ts file.
By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 20:04 -
AutoGK - Bigger file = better quality?
By kelemvor in forum DVD RippingReplies: 13Last Post: 8th Jan 2008, 23:15 -
DVD Shrink to VOB,IFO, BUP and then IMGtool to ISO, bigger than 7GB
By opieandy in forum DVD RippingReplies: 3Last Post: 28th Sep 2007, 16:04
