Hello,
Is there a good GraphEdit filter around I can use to encode 4-5 mono wave files into one Prologic/Prologic-II encoded wave file?
If there ain't any - is there any good (free!) standalone tool I can use?
Prologic is analogue, not really encoded. You can flag it as PL, and let the chips fall where your PL amp plays them.
If you have 4 or 5 mono wavs, why not make them AC3. Your player will downmix them to stereo of you use the analogue outputs, and you can still run them through a PL amp if you want.
If you only have a mono track, or even just a stereo track, then you may as well leave it alone.
Here is the last response to a similar request https://www.videohelp.com/forum/viewtopic.php?t=270905
This forum is littered with many similar requests/responses.Read my blog here.
AC3 is nice and probably the best choice as long as you keep the audio digital (by the way if you know about a good free AC3 encoder, I'll be happy to hear that too).
However, if I'd like to record it on a tape (yeah I know it's old and useless, but still), then any digital encoding cannot be used. As far as I know, Prologic is the only way to encode surround sound to analog tape.
Selecting passthru audio in MPC HC rather than the prologic
By skinney6 in forum AudioReplies: 2Last Post: 26th Jan 2012, 11:37 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Dolby ProLogic in PHILIPS
By anirban in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Oct 2008, 16:09 -
Dolby Prologic IIx. I understood that it will "create" a surround
By andrema71 in forum AudioReplies: 3Last Post: 6th Jun 2008, 10:22 -
ac3filter - back speakers no longer working for Prologic output
By pglenn in forum AudioReplies: 0Last Post: 6th Nov 2007, 23:09
