I have 2 files that are avi. I joined with virtual dub that were about 750mb each after the join the total conbined files was 83GB. I was anticipating around 1.4GB not 83gb. What would I be doing wrong I wanted to put this on a dvd after a mpg conversion.
Thanx all.
Hi-
What would I be doing wrong...
You have to set Video to Direct Stream Copy. You reencoded the whole thing uncompressed. -
...but if your next step is to create a DVD specs mpg, you could as well use your 83 GB AVI as source, if you have any HDD space left.
/Mats -
can it be join in its original compressed format to get me to about 1.4GB, and still be able to convert to a dvd. I don't have any space left to do anything else.
Probably, if the two files are "identical", that is use the same codecs, resolution & cetera. Just do as manono said, set both audio & video to direct stream copy.
/Mats -
How about making your life easy. Just make an AVS file with the following:
Code:avisource("file1.avi") + avisource("file2.avi")
Yup, most things are most easily solved with AviSynt, if you know how to operate it. Since most people seem to be very frightened of entering commands using the keyboard, (Thanks, M$!
) a roundabout pointanclick way seems to be the best recommendation on most occations...
/Mats
Joining AVI Files in VirtualDub.
By eliqush in forum EditingReplies: 12Last Post: 6th Jul 2009, 03:31 -
Error In Virtualdub Joining Two Like DV Files. Help?
By kpoman in forum EditingReplies: 2Last Post: 7th Jan 2009, 11:34 -
Joining a movie with 2 parts together using virtualdub!!!
By SaM*T in forum EditingReplies: 1Last Post: 17th Sep 2007, 14:09 -
Joining avi files with Virtualdub
By JaredKnight in forum EditingReplies: 10Last Post: 8th Jul 2007, 20:45 -
Joining AVI videos in virtualDub ?
By Dj-DuDu in forum EditingReplies: 3Last Post: 13th May 2007, 13:31
