Hello,
what I am making bad to pass of a VHS Video to the PC throught of the dcr-hc30 I do not comment to you:
I have connected the Video to the Video camara by RCA from a euroconector of the Video.
and the Camara Video to the Computer by Firewire.
- the capture by firewire Works - If I connect the Video to the analogica capturadora, confirms that this emitendo by eurconecto+rca -
I have assets in menu of camara opcuion A/v->dv and in Input Video:
Video (I also tested by s-video) - I do not introduce any mention in camara - I put it in way to play But nor in videocamara the signal of the analogico video is seen, and clear it does not arrive either at the computer. Somebody has some idea, that I am making bad? Thank you very much.
Let me see if I have this straight
1. You are trying to captute VHS through your DV camera analogue pass through
2. You have connected the VHS scart (Euro) connecter to the camera's analogue inputs
3. You have connected the camera to the PC via firewire
4. You can see the video from the VHS in the camera, but not on the PC
What software are you using on the PC to transfer the DV footage ? You have to disable the software trying to control the camera and just let it feed through. How you do this depends on what software you are using.Read my blog here.
You can not use a europeon camcorder for pass through. It has some copy protection built in. It is some kind of europeon customs limitations where a camcorder can not be used as a vcr. There is some kind of work around out there on the internet but I have no idea where it is at.
thank you very much
Solved the problem. it was that the options of camara must be:
[DISPLAY] = [LCD PANEL]
and when having changed it send by same input signal RCA
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 16:18 -
Analog to digital pass through with Sony Handycam DCR- HC65
By Gerald Sr. in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2008, 00:18
