Hi, is that possible? A DVD that would play on the TV, as a normal Video DVD, but also contains DATA?
i'm wondering whether someone has already tried to have the standard VIDEO_TS and AUDIO_TS but also add a folder called DATA that contains file that can be read on a PC?
Thanks,
Alan.
I believe this can be done and I think the guy who started this post mentions that he has successfully done it.
Read through the post and you should find a mention of it somewhere, I believe he uses the software RecordNow 7.3,
Edmund Blackadder,
https://www.videohelp.com/forum/viewtopic.php?t=225001&highlight= -
Yes. At least it doesn't break any standard.
/Mats -
Not all authoring software supports it, but all you really need to do is add another folder at the same level as the Video_TS folder. It can be called pretty much anything you like. I do this with scans of original photos that are also included within the dvd title itself as a slideshow.
Read my blog here.
Author to HDD (VIDEO_TS and AUDIO_TS folders)
Create DATA folder "beside" DVD folders.
Fill DATA folder with stuff of your choice (making sure max media capacity isn't exceeded).
Make DVD image with imgtools classic
Burn with DVDDecrypter
/Mats -
Thanks very much (i was a bit nervous for my first post)...
Now, I may be pushing this too far, but any chance I can make an AUTO START PC file on that DVD? I have a setup.exe file that ideally would start on the PC as soon as the DVD is entered. I assume the file would have to be placed in the root of the DVD. Is that a problem?
Thanks again for your help guys. -
Yes, even that should be possible, AFAIK.
/Mats
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 18:53 -
Can't see data on a DVD-RW ! Please help!
By Icaro in forum MediaReplies: 10Last Post: 20th Jan 2011, 05:45 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
It plays OK on the PC but not the DVD?
By thief_ in forum DVD RippingReplies: 4Last Post: 12th Jun 2008, 05:52 -
plays cd and not dvd
By london053 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Nov 2007, 08:26
