hey all, i use tmpgenc plus v2.5 with the 352x240 kvcd template to convert avi movies to
MPEG-1 352x240 25fps CQ 60, Layer-2 48000Hz 128kbps
this will play in a dvd player if i burn this onto a cdr cd, what im wanting to do is to add more than one movie converted like this onto a DVDR cd and it also to be able to play in a dvd player, but i dont know how to do this.... i have tried using vcdgear to add the movie tracks and let the size to get up to about 4.3gb, convert to bin/cue ... but i get errors when i try to burn the cd image... any suggestions?![]()
----> adamf9898 ---->
You need to use an authoring program - this way you can even create a menu for your multiple video files.
You could try DVDAuthor and DVDAuthorGUI or DVDStyler which are free.
Personally I use DVD Lab Pro.
Once mastered you can burn the DVD using your favourite burning software (DVDStyler can do that for you actually) - I personally use Nero and am happy with it
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14 -
I need a guide fot adding subtitles to DVDR of series- not movie
By dallylama in forum SubtitleReplies: 4Last Post: 8th Jan 2008, 21:22
