I have an HE-AAC 5.1 file at 22050Hz. I want to convert it to AC3 5.1 so that I can put it onto DVD.
First, I created a 6ch WAV from the AAC using AACDecDrop. Next, I need to change the sampling rate to 48000. What tools do I use to do that? This 6ch WAV is 1.47GB and has a length of 1:39:52. I've tried many ways but nothing works correctly!
I have tried SSRC and SSRC_HP but it gives out corrupted files for some reason.
In Cool Edit Pro, after I converted the sampling rate to 48000, the WAV sounds fine but the file's length was shortened to 1:39:45.
Any help is greatly appreciated.
this reminds me to a filesize limit-> are you using a FAT or a NTFS partition? If FAT (of any kind ->16/32) your file size is limited to 2GB, after conversion you should expect a file size about ~3.2GB.This 6ch WAV is 1.47GB and has a length of 1:39:52. I've tried many ways but nothing works correctly!
for working on 6WAVs I found a nice freeware app called Audio Cutter Cinema (you will find this app @ needfulthings
6CH DTS Channel Order?
By maxeemo in forum AudioReplies: 4Last Post: 14th Apr 2011, 16:58 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 07:12 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
Is there upsampling software?
By dbbd in forum DVB / IPTVReplies: 3Last Post: 29th Apr 2008, 12:00 -
Increasing voices in 6ch audio
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 16:21
