hi all i have sound forge 8 and want to load a ac3 audio file but it will not load sasy unkown file format.
the problem with the audio is the left and right channels are the wroung way round and i want to swap them and also the trebbile is way to high watn to lower it
so is there a way to load the ac3 file to do this and then save it back as ac3 file or a dvd lyaer format
hope you can help
if not on sound forge any other progrma that lets you do what i need to do
thanks once more
I think you will need to convert the AC3 to .Wav then encode to AC3 again.
If it's only 2 chan, virtualdubac3 (or virtualdubmod) will rip the ac3 to .wav
Swap the channels in Goldwave.Cheers, Jim
My DVDLab Guides
Sound Forge puzzler...
By mjl1297 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2011, 09:19 -
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 14:12 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 08:46 -
Removing Scratchiness with Sound Forge 8?
By solarblast in forum AudioReplies: 12Last Post: 17th Nov 2008, 11:30 -
Goldwave or Sony.Sound.Forge
By lucid_dreams in forum Newbie / General discussionsReplies: 4Last Post: 1st Mar 2008, 01:33
