I have a few DVD-R's I want to get the audio to put on a CD-r. I think I could use my software to recrod, "what you hear" but it would be real time. Is it posable to just get the whole sound file?
I want to open it up in my wav. editor (Sound Forge) and edit some parts out to get it just the way I want, then burn it on a CD-R. How do I do this? Thank you, Chris.
I use a roundabout way.
I use ReJig and demux the whole audio track.
I then transcode it to .wav in virtualdub-ac3.
Edit as needed in Soundforge.Cheers, Jim
My DVDLab Guides -
When you say audio from dvd-r, do you mean dvd video. if so, try dvd audio extractor.
I use either VirtualDub-MPEG2 or VirtualDubMod and just Save WAV and then use a sound editor to edit the Wave file.
i nuse virtualdubmod in conjunction with chapter extractor in case you want to rip specific chapters(dvd concert)
I love it when a plan comes together!
Easy tool to change audio fps
By davidbowie in forum AudioReplies: 20Last Post: 17th Jul 2014, 04:23 -
I need an easy way to play PC audio over microphone line.
By Nagashi in forum AudioReplies: 3Last Post: 11th Jan 2012, 18:36 -
I need an easy way to replace audio tracks in a DVD
By sanguino2001 in forum Authoring (DVD)Replies: 6Last Post: 2nd Aug 2009, 12:00 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
Easy way to mux new audio track into DVD?
By MrMoody in forum DVD RippingReplies: 2Last Post: 2nd May 2008, 20:28
