I want to play a dvd with dts on my laptop i can see the movie but have no sound is there a kind of codec that i caninstall so i can hear the sound
I think that both your player and the audio needs to both support the DTS format. No codec will help.
Media Player Classic has a built in DTS decoder.
ffdshow and newer versions of AC3Filter also supports DTS. All are using the same lib (from VideoLAN), so quality should be the same.
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
Problem with HD-DTS to AAC
By Z.Sath in forum AudioReplies: 2Last Post: 24th Apr 2009, 09:58 -
DTS problem with AutoGK
By extrabyte in forum AudioReplies: 0Last Post: 10th Jan 2009, 13:43 -
Dts Problem.
By naTTan in forum AudioReplies: 2Last Post: 23rd Feb 2008, 02:40
