Hi,
I created a slideshow with Adobe Premiere Pro and insert markers at each picture. I extract this sequence as m2v file to use it in Adobe Encore DVD.
That way I hopped being able to create chapters in my DVD.
But that never works, I can't find back my markers set in Premiere.
Could you give the method to create chapters ?
Thx
If you don't have any luck here, head over to www.wrigleyvideo.com - there's forums and tutorials for a number of Adobe products, including Premiere Pro.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
In Premeire Pro when you set a marker to use as a chapter point you have to make sure that you give the marker a name in the Chapter field (just double click on the marker and type a name in the chapter field) since that is what Encore requires in order to import the markers in Encore. If you don't do this then the markers wont appear.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
OK thanks for tricks.
Unfortunatelly for tutorials, I did not find anything interesting...
Other links ??
How do I create a slideshow of photos and short movies?
By wreckage in forum Newbie / General discussionsReplies: 8Last Post: 21st Oct 2011, 03:44 -
create slideshow
By shashgo in forum Newbie / General discussionsReplies: 27Last Post: 14th Aug 2008, 11:13 -
Want to Create Slideshow DVD to show on My HDTV
By 1deciple in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2008, 15:54 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
App to create slideshow as video???
By vulcan4d in forum Newbie / General discussionsReplies: 5Last Post: 20th Jan 2008, 20:56
