Hi,
Ive been trying to encode some avi file to dvd but they keep failing. this is the error message i get.
any help would be appreciated,
thanks
Encoding started on Fri Jun 10 02:28:58 JST 2005
Input #0, avi, from '/Volumes/music/suprnova/thebottlefools/thebottlefools.avi':
Duration: 01:37:19.8, start: 0.000000, bitrate: 1006 kb/s
Stream #0.0: Video: mpeg4, 624x352, 29.97 fps
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 131 kb/s
Output #0, rawvideo, to '/Volumes/Untitled/bottle.mpv':
Stream #0.0: Video: mpeg2video (hq), 720x480, 29.97 fps, q=2-20, 4000 kb/s
Stream mapping:
Stream #0.0 -> #0.0
video:2851313kB audio:0kB global headers:0kB muxing overhead 0.002857%
bench: utime=10101.850s
error: could not convert audio track!
DigiCoreAudioDriver> Found 9 entries in 'SupportedApps.txt'.
Input #0, wav, from '/Volumes/Untitled/bottle.wav':
Duration: 00:00:00.0, start: 0.000000, bitrate: 1537 kb/s
Stream #0.0: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Could not open '/Volumes/Untitled/bottle.ac3'
Results 1 to 12 of 12
You should get the ac3 file you obtained previously, and encode it to mp2 with the "audio to mp2" ffmpegX preset. Then use "Mux as.. DVD" to combine the m2v video track with the mp2 audio track. No re-encoding of the video track is needed.
when i open the ac3 file as the source format in the summary page it comes up as unrecognized and when i choose the audio file to mp2 option in the taget format section and encode it finishes instantly and no file file is produced.
tryed to load it in the audio page but nothing happened also the only file i have from my last staright avi to dvd encode are an ac3 file, an mpv file and a wav file.
any ideas?
thanks again
encoded the avi file to dvd with normalize on...then tried to mux to dvd with the ac3 and mpv files but nothing happened...finished process straight away! if i choose to encodee avi with normalize off then i dont end up with an ac3 and mpv file only a video_ts and audio_ts folder.
where to from now?
thanks for the ongoing support major.
How to convert AMR audio track to something else with the video unchanged
By rlew in forum AudioReplies: 3Last Post: 29th Aug 2009, 11:05 -
using VOB2MPG to convert WITHOUT the commentary audio track
By wildrthanevr in forum Video ConversionReplies: 4Last Post: 16th Mar 2009, 12:57 -
convert XviD to DVD format but lost audio track 2
By zenghe in forum Video ConversionReplies: 2Last Post: 3rd Mar 2009, 17:34 -
convert 2 audio track xvid file to ipod 3g
By felix in forum Video ConversionReplies: 1Last Post: 8th Oct 2008, 15:45 -
How do I convert .ogm file to .avi and keep a certain audio track?
By Moldiver in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 09:43
