Hi I am looking for a easy to use converter to MP4 for the Sony Ericsson K750i. I havent found any yet, I have noticed that there are a few PSP video creators. I have listed below the info from the Sony sites regarding if what the PSP and the K750i will support. Can someone tell me if the PSP creator software will be ok for use for the SE K750i. I havent got the K750i yet and so cant test it.
K750i
Video (including audio part):
- MP4 (video: MPEG4, audio:AAC or AMR)
- 3GP (video: MPEG4 or H.263, audio: AAC or AMR)
PSP
[Video]: "Memory Stick": MPEG-4 SP,AAC .
if it does this would be great. I'm looking at PSP Video creator from www.pqdvd.com and other various PSP video creators which would let you select the resolution of the K750i which is 176X220
hope someone can help.
thanks
Hi loc-man
I use mpegablex4 live converter
Try searching on google.
using this program you can convert to 3GP or MP4 which will both work on K750i
Also look at Esato.com which has guides.
.MP4 for mobile phone problem
By the_provider in forum Video ConversionReplies: 0Last Post: 25th Dec 2009, 20:49 -
Encoding iPod/mobile + PSP AVC compatible files.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 03:42 -
mp4 sound not supported
By dnix71 in forum ffmpegX general discussionReplies: 7Last Post: 14th Jul 2009, 12:45 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 11:59 -
MP4 on WiMP Mobile?
By Memo_182 in forum Portable VideoReplies: 3Last Post: 7th May 2007, 16:34
