I can't get any program to convert xvid to dvd. When i run it threw g-spot this is what it says after I render it. Video-(S) --> AVI Splitter --> DivX Decoder Filter --> (R) Audio-(S) --> AVI Splitter --> MPEG Layer-3 Decoder --> (R). Any help would be greatly appreciated.Thanks!
Results 1 to 9 of 9
hi,
Have you tried TMPGENC PLUS?
Originally Posted by zackbaby
http://www.download.com/VSO-DivXtoDVD-Converter/3000-7970_4-10376028.html?tag=lst-3-7
I been using it for 3 months now ez to use and its free -
Thanks for the info but I've tried both of these progs and they just crash my computer after it gets about 10% done. Please,Any other ideas? Thanks again!
my pc
AMD DURON 1.6
512 MB DDR 3200
MSI KT-266A
XP PRO SP1
SAMSUNG 80GB HD
not a single crash yet -
I'm not sure ,but this may help
update your OS
flash the MB BIOS
check and see if your CPU temp isn't too high
check the memory for errors -
I notice that you are using DivX to decode. Do you actually have XviD installed? Because a lot of converters require a VfW decoder.
Does sound like maybe you have some hardware issues though. -
Thanks for the help. It was a memory problem that kept crashing my computer. Thanks again for the help and info.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
