Results 1 to 13 of 13
    Feb 2004
    Hey all
    I need me a good software to convert a dvd to an avi file. Whats the best one on the tools page. Your help is very appreciated.
  2. Member Adub's Avatar
    Mar 2005
    california
    Yeah autogk or you can try #1 DVD Ripper. with #1 DVD Ripper you don't have to rip it to your hardrive first.
    Feb 2004
    what about dvx
    Feb 2004
    doesnt AutoGK have spyware???
    Aug 2003
    Fairuse
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    AutoGK is the best for me.
    What's best for you ...... only you can answer that after trying them yourself
    If in doubt, Google it.
  7. Member ricardouk's Avatar
    Mar 2005
    Portugal
    DR divx(i know some will say that is crap, but it never failed me)
    autogk always crashes on me .
    if you choose freeware i would pick Fairuse wizard (i like the sub position function, among others)
    hope it helps
    I love it when a plan comes together!
  8. Originally Posted by Merlin7777
    So with dvd ripper you can just select certain parts to rip to avi? That's kinda what I'm looking for.
    What about dvd to mpeg2? is that faster?
  9. any one of these allow me to just compress with xvid? I want to keep the resolution/aspect ratio and audio the same.
  10. Can I use any of these for VOB to DV conversion? They don't actually list VOB as their formats, which I've found in the past usually means they can't....
  11. If you only want bits you can rip it, mux it then use Virtualdubmod to convert the bits you want to DivX
