  1. Hi:
    I use goldwave to clean up the audio from dvd backup files I have on my hard drive. The problem is there is a couple of dvd backup files that goldwave wont allow me to use. Everytime I try to add the files to goldwave I get a error saying: Abnormal program termination. Is there a way to correct this error or is maybe there is a problem with those particular files. If so is there a way to test to see if these files are ok and if not is there a way to repair these files.
  2. See if you can rip the audio in virtualdubmod.
    Load the .wav into Goldwave.
    Cheers, Jim
    My DVDLab Guides
  3. Im not sure how to do that. What are the steps to rip the audio in virtualdubmod.
  4. Open the video, select Streams, stream list.
    RIGHT click the audio track, select Full Processing.
    Selec Save .WAV
    Cheers, Jim
    My DVDLab Guides
