    May 2005
    san diego
    hey, how's it going, i'm jeremy, i'm a closet techie, but have very little knowledge about these things.
    my office has dsl connection. I live in mexico. connection costs down here can be somewhat expensive (looking to spend about 1000$ for a year for home broadband connection.) since the office is already wired, and i live about 1 mile away, what could be a setup to be wireless at my house and still get a decent signal. let's say 11mbps i'll accept. i've got this friend (don't we all) who says about 2k$ and i can set it up right, but i'm thinking there's got to be a cheaper way to do it. any thoughts from the peanut gallery?
  2. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Here's a few starting numbers.
    The standards (PC Magazine) for 801g indicate 120M line of sight outdoors. I have read articles about people getting reception at 1000 feet using some of the newer MIMO technolgy under perfect conditions (no standard yet on 802n).
    I believe a mile is roughly 5,280 feet so you would need to use several "extensions" which are like repeating access points. I believe the greatest difficulty using "off the shelf" technology would be finding 7 or 8 places along the route to install the repeaters. Then again, you have to have a wireless router hooked to your office network to start the whole thing off.
    For $2,000, your friend must be talking about an "industrial solution" similar to what some of the Amercan cities are starting to install (very large broadcast dishes basically).
    May 2005
    san diego
    k, so without those repeaters there's no budget solution to my problem, i'll just have to eat it.
  4. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Yeah, directional antennas are probably good to about a 1/4 mile on a clear day, far less during inclement weather or if it rains mirrors and lead sheets.
    Is it feasible to run a fibre-optic cable underground between the two? If it were mostly rural between home and work it could be a feasible alternative. I think the terminals on each end may be pricey, but not $2k pricey. And then you'd have blistering fast speeds with your LAN between home and work.
    FB-DIMM are the real cause of global warming
    May 2005
    san diego
    yeah, it's not going to be worth it in the end. i'll just have to pay at the house too.
