I'm new to video capturing. I bought the TV WONDER USB 2.0 and I've been trying to record in avi. I can set the video codec to whatever codecs I have installed, I'm using the XVID codec. But under the audio codec list it shows only the list of codecs the software provides and it has an mp3 option but it shows 44hz 0bit under the entire config list for that codec. So if you use it it doesnt record the sound. Does anyone know how to get an external mp3 codec (lame) to work in the ATI software or is there another program I can use. Thank you
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 02:21 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23
