I have searched the guides but couldn't find a way to put an AVI file on a DVD without converting it to an MPEG format. Is it possible to do this as long as the file is under 4GB?
Thanks Much
Hi,
Only if you desire to play it on a computer or a divx compatible dvd player. Otherwise you will have to convert it to mpeg.
If it is divx compatible just burn the data file without doing anything to it.
Any file up to the media size limit can be burned to DVD as data under UDF format. Some burning programs allow mild overburn. You can also span a huge file over several DVD media. An AVI is just like any other data file.
If you want it to play on a standalone player, burn it to the supported standards of the target player. -
download the DIVX to DVD converter. It converts AVI files to VOB files. thats what i use and it works good.
Mpeg vs. Avi for VHS to DVD
By smartel in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2011, 10:39 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
dvd to avi or mpeg
By AeR0 in forum Video ConversionReplies: 3Last Post: 22nd Jan 2010, 12:45 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DVD to MPEG-2/AVI
By Nitro89 in forum DVD RippingReplies: 21Last Post: 14th Apr 2008, 14:17
