Alright, I have the ILO DVDR04 ... upgraded with latest firmware
okay.. problem.. almost everytime i record something.. on to dvd+rw and I use dvd decryptor to put the files on my computer.. it says " PACK HEADER NOT FOUND " well, after that, it finishes... so I'll load my .vobs into womble mpeg vcr, and half the video is gone, or it freezes on a frame, and its gone... whuts causing this?!
my media is SONY 1x-4x DVD+RW I even have some free media from supermedia store ive tried, does the same thing.. its also +RW.. any help, Thx!!!
only_emo_kidGuest
Try extracting, joining and saving the VOB's to a single .MPG file with Simple File Joiner (free)
http://www.peretek.com/sfj.php
Then load the single .MPG into Womble for trimming. That may work for you. That's what I do, and it has worked great for me. I've run into a couple of issues similar to what you decribe when I've used Decrypter to extract and save the VOB files. -
only_emo_kidGuestOriginally Posted by gshelley61
That didn't seem to help, it doesn't give any errors... but the output .mpg doesn't seem to be complete and wants to freeze when skipping through to check it... and in womble, It loads up, and i'll scroll from left to right, and it shows americas funniest videos, then i get to the end, and i'll scroll right to left, and it shows maximum exposure tv show... so its like showing 2 differ things when the slider bar is in the same spot... so I don't understand? -
It sounds like you're going to have to save each VOB separately to your hard drive (no need to use Decrypter or anything else... just click and drop in Windows).
Then try loading each separate VOB into Womble one at a time for editing. See how that goes. -
tried that directly from the dvd with womble... still doesn't
don't know why
Thx for suggestions tho
Not directly from the DVD... that usually causes problems for Womble (stuttering, etc.) Save the VOB's to your computer hard drive first. Then load them from your hard drive into Womble.
I've had some luck using VOBBlanker as sometimes various problems are introduced to the front end of the video and the program can remove them.
Anymore, I start the recorder a few minutes early and record a little past the end and then trim the result. Nyah Levi -
only_emo_kidGuestOriginally Posted by nelson133
I just tried vob blanker, and as soon as I loaded that .ifo or whutever file it wanted.. the first thing it said was Cell not found...
panasonic bluray recorder problems with grinding noises when recording DVDs
By hargels in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Apr 2012, 17:52 -
help recording my laptop with dvd recorder
By xtube in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2010, 12:41 -
recording a mpg file right to dvd recorder
By abrand88 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Feb 2009, 19:47 -
DVD Recorder, TV Recording, and Interlace Question
By CobraPilot in forum Authoring (DVD)Replies: 9Last Post: 20th May 2008, 20:53 -
Recording from one DVD recorder to another?
By Trollheart in forum DVD & Blu-ray RecordersReplies: 24Last Post: 17th Mar 2008, 17:54
