I'm curious to know if encoding an edited DV video to Quicktime would be any different if mac os x is used instead of Windows XP. Does apple tweak the codecs differently for the two platforms?
Similar question: any differences between encoding/rendering to quicktime directly from Vegas/PremierePro versus going to an uncompressed avi first, then through Procoder Express? I would think that all these programs use the same Quicktime codec installed on the pc, right?
I see the quality of the movie trailers on the apple site (encoded on macs, I assume), so I thought I'd give quicktime a shot for my home movies that I put on my website for friends and family (encoded on my XP Pro pc) (currently encoding to WMV9, but I get some blocky output sometimes...most likely user error).
Thanks!
Gary
Same codecs and apple really don't have any decent ones. Sorenson isn't that special, their MPEG4 codec is just crap and their AVC codec doesn't sound that special.
the trailers on apples site are not made from DV files is one reason they look so much better ...
If not from DV, what is the source? Film? And wouldn't that suffer from an analog-to-digital conversion?
Thanks for the replies.
Gary -
Yes, Film.
They are run through Rank Flying spot telecine scanners (or similar).
Yes, it is an analog to digital conversion, but one can very likely go to file formats that support extended quality-HD/2k/4k resolution, 8/10/12bit RGB or Cineon Log color depth, possibly temporal oversampling (2x/48fps or 3x/72fps)--UNCOMPRESSED!.
Then, they are digitally downconverted (hopefully using correct dithering, color spectrum translation, etc).
Makes a HUGE difference!
Mac OS X Lion QuickTime Player Choppy Audio
By zBernie in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 20:05 -
capturing quicktime on mac
By devdev in forum MacReplies: 2Last Post: 18th Nov 2010, 15:33 -
Capture HD from Canin HDV20 to Quicktime Pro - Apple Mac
By segovia123 in forum MacReplies: 0Last Post: 13th Feb 2009, 05:41 -
MKV to any Quicktime-supported format - for Mac
By brijazz in forum User guidesReplies: 2Last Post: 8th Aug 2007, 17:07 -
YouTube (.flv) to QuickTime (.mov) on Mac OS X 10.4 doesn't work
By sailmariner in forum MacReplies: 4Last Post: 3rd Jul 2007, 07:09
