Hello! It's my first post here in a while so be gentle.
Firstly, I'm on Windows XP behind a Belkin F5D6230-3 router. I've forwarded my ports on that and my software firewall (Norton) is allowing it internet access.
I think however that the problem lies with the IP address which the FTP server is trying to listen using. Whenever I run it off my internal Ip address (192.168.2.4) I get a green light and the program tells me everything's operating as it should. However, people can't access my server using that IP can they?
I therefore tried altering the IP to my proxy IP and my external IP - both of which I obtained from whatismyip.com. This time, a red light was displayed for each IP, and the program suggested the server was running from an IP which did not exist.
Can anyone suggest which IP I should be using or perhaps somewhere else where I've gone? Or could anyone suggest a more simple FTP program to use?
Thanks everyone!![]()
Put your server's IP back to the private internal address assigned to your system.
On the router, open up Port 21 or 22 if you are using SSH. Forward all FTP traffic (port 21) to the itnernal 192.168... address of your server, or workstation running SFTP server.
Tell teh other people to connect to your IP you got from whatsmyip.com and your router will forward them to your internal address for you.
LS
Best way to upscaling video from 720p (30 ftp) to 1080p (60 ftp)
By siopilos in forum Video ConversionReplies: 3Last Post: 1st Nov 2011, 19:40 -
Need advice on setting up a home media server
By jamietallman in forum Video Streaming DownloadingReplies: 2Last Post: 7th Jan 2009, 01:25 -
Changing NAT Settings On The XBOX 360
By Nitro89 in forum Off topicReplies: 0Last Post: 8th Nov 2008, 12:49 -
What is NAT for routers and is it needed for PS3 gaming?
By yoda313 in forum ComputerReplies: 15Last Post: 12th Jul 2008, 10:00 -
Setting up my own FTP with Bullet proof FTP
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 25th Jul 2007, 09:48
