xp does not show existing data (in data cds as well as vcd's) in my cdrw.
e.g. I have 150Megs in my cd. xp claims the capscity is
650-150 = 500Megs and all 500 Megs are free!
So now I am forced to pull data from other machines in my network. Thank goodness, I have them?
anybody has seen this problem?
is xp recognizing your drive as a cdrw, check under properties and see if you have a write speed tab, if you don't make sure your cdrw drive is the master on the ide port, if it is then check to make sure your drive does not have compatability problems at the windows site, xp recognized all my disks weither I crated them with cd creator or incd.
you may need to install a UDF reader.
Adaptec and Nero have them.
I know it required me to install a UDF reader to open CR-RW -
Thank you guys
As suggested I installed the latest xp udates and that seems to have fixed the problem
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 18:53 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
adding new subtitles over existing ones
By fishdog in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2010, 03:22 -
Edit Existing DVD
By prncess23 in forum DVD RippingReplies: 2Last Post: 4th Sep 2009, 15:52 -
Cutting an existing DVD
By stumpman13 in forum Newbie / General discussionsReplies: 7Last Post: 6th Aug 2009, 11:49
